Temporary sign supports using bolted telespar posts?
Well, I tried this over in the T.E. forum for over a week and got zip. So now I'm trying here.
I'm looking for a NCHRP 350- or MASH-certified temporary sign stand that uses bolted connections.
We have plenty of telespar tubing, so I was thinking of using this one, but our shop welder can't weld the galvanized tubing.
ht tp://www.w sdot.wa.go v/NR/rdonl yres/31E74 DC3-C8CC-4 389-8A16-F 4F7603AC09 9/64393/Po rtableDeto urRouteMul tipleSignA ssemblyExa mples4.pdf
Thanks!
ht
Thanks!
Maybe the tyranny of Murphy is the penalty for hubris. - http://xkcd.com/319/
RE: Temporary sign supports using bolted telespar posts?
If you go bolted only, then you'll need knee braces in each direction.
