ASME B31.3: How does fluid temp affect hydrotest pressure?
I have a 10"/12"/14" Sch 80 900Lb ASTM A-106 Gr. B SMLS process line which as per our company pipe spec has a hydrotest pressure of 18,735 kPa @ 38 deg.c - now the ambient temperature is more likely to be 18-20 deg.c therefore the fluid temp will drop accordingly - how will the drop from 38 deg.c to 20deg.c affect the hydrotest pressure? I know it will drop but is their a relationship for this?
RE: ASME B31.3: How does fluid temp affect hydrotest pressure?
