Stress Analysis buried pipe
Hi:
I need help, about how to input data for a pipe stress analysis in a buried pipe, 12", with casing and inside of another pipe (16"). This is for a pipeline, crossing a river about 45 ft & underground like a 9ft under a bottom of river.
I have all the info of ground for the module of buried pipe in Caesar II. I have triaxial UU essay result's of ground for each side of river.
Thanks for the support.
Best Regards,
Luis Felipe Cadena.
Best Regards,
Luis Felipe Cadena.
RE: Stress Analysis buried pipe
Richard Ay
Intergraph CAS
If you can guide me through this consult, I am very grateful with you.
Best Regards,
LFC
Once your comfortable with this, build your model. It sounds like you have a jacketed system. I'd suggest building the core piping, duplicate that to the jacket, bury the jacket, then go back and add the CNODES to connect the jacket to the core.
Richard Ay
Intergraph CAS
