enable SMP
enable SMP
I've found out about this setting in ugii env.dat,
For multi-threading. I have a dual processor machine with Xeon 2Ghz E5504's,(NX6.0.5.3) i'm wondering will i see any benefits, in general modelling?
# MISCELLANEOUS
# This variable enables Symmetric Multi-processing (SMP) on systems
# with multiple CPU's or that support hyperthreading. Performance will
# be improved in certain Parasolid operations, such as Mass Properties,
# Booleans and silhouette generation. This option is only supported on
# HP, SUN and Windows NT.
# Set to 0 to disable SMP
# Set to 1 to enable SMP
# Unset will take the Parasolid default
#if ${NUMBER_OF_PROCESSORS} = 1
UGII_SMP_ENABLE=0
#else
UGII_SMP_ENABLE=1
#endif
Also, assuming i add the "UGII_SMP_ENABLE" as an enviroment variable should the value =2 , as the code implies?
Thanks....
# MISCELLANEOUS
UGII_SMP_ENABLE=0
#else
UGII_SMP_ENABLE=1
#endif
Thanks....
RE: enable SMP
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
RE: enable SMP
RE: enable SMP
Ben Loosli
RE: enable SMP
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: enable SMP
I have a dual quad-core and NX6 crawls around on one core. And many operations I'm doing lately are on LARGE assemblies where one simple hide or unhide command can take minutes. At least I have 7 other cores available for wasting time while NX goes through it's seemingly numerous inefficient routines.
Justin Wade
Mechanical Engineer
RE: enable SMP
Except for very specialized applications, where independent processes can be decomposed into parallel tasks which can then be reassembled back into a valid result at end, most general purpose software applications, particularly those which have evolved from when there were no practical multiprocessing hardware, are not generally suited for conversion to taking extensive advantages of multitasking. It's just a fact of life.
And besides, the reality is that in those cases where specialized applications HAVE been developed which CAN leverage multitasking in a significant way, these generally requires that the hardware be dedicated to running ONLY that application. However, that's exactly opposite to what's happening since products like NX are being installed and run on general purpose desktop (and even laptops) systems used by designers and engineers for many different tasks, many of them in use at the same time, and it's this situation where todays multi-core architectures are able to deliver the best overall performance and payback. Only when you look at what you do over of the course of say a day or a week of operation, performing a multitude of tasks using several different, and in many cases, independent software products, only then will you see the benefits you gained by using multi-core configurations. In the end, the degree to which any one of these applications did or did not leverage the multiple-processors available to it, this will have very little measurable impact on your overall productivity, not when compared to how having access to multiple tools on a common office platform, all of which were performing well, delivered an overall return.
John R. Baker, P.E.
Industry Sector
Cypress, CA
