Calculation Coil Pressure Drop
Trying to balance some hydronic coils. I have the design gpm, actual gpm and design water pressure drop. Is there a formula to calculate the actual pressure drop?
RE: Calculation Coil Pressure Drop
dp(q1)/dp(q2)=(Q1/Q2)^2
that is: pressure drop is proportinal to the flow rate (actually its velocity) squared
Best regrads
Morten
http://en.
f(coil) = f (straight pipe) *[1+3.5×(d/D)]
f = Moody friction factor
d =inside diameter of the coil tubing
D= Diameter of the helical coil
Reference: Matthew J.Realff & Jde T sommerfield
Georgia insitute of technology)
In addition, if flow is laminar, dp(q1)/dp(q2)=(Q1/Q2)
"We don't believe things because they are true, things are true because we believe them."
Data for friction factors in coils depend on their geometry, e.g. helices, flat or cylindrical spirals, turbulent and laminar conditions, newtonian and non-newtonian fluids.
I found another formula for helices:
The friction factor, ƒ, can be used to estimate friction drop, Δpf, using:
Where:
d and D as above; ρ = density; v = velocity.
