Finding and grouping values within a range
I am having some trouble identifying the function or the method that I need to use to go about my issue.
I have exported a bunch of data into excel showing the data & time, pressure and flowrate. What I want to do is be able to identify atleast one hour periods of time that have a relatively constant pressure (i.e. a range withing -/+ 5 psi) and see what the flowrate during that period is. I have tried several excel functions such as Vlookup and match/indes, however, these are not powerful enough to do what I would like. I am having a hard time finding a function that can identify up to one hour blocks of time which also have a relatively constant pressure. I have a feeling this might require some VBA coding, however, I do not have any experience in VBA.
I have attached the spreadsheet containing the data I am working with to give you an idea of what I am talking about.
Your help is much appreciated.
RE: Finding and grouping values within a range
CODE
(2B)+(2B)' ?
jghirst your example helped me out a lot though, gives me a better idea of what to do. What do you think I could do in the case that the time intervals are not constant between subsequent pressure and flow measurements?
htt
