Oil Removal from Demineralized Water System
I am currently trying to determine how to flush/rinse oil from a demineralized system. water system. This water system is a closed loop cooling water system for lubrication oil, however a leak developed in the heat exchanger and we found oil in the water. Has anyone had experience with cleaning agents or methods to rinse out the oil from a demineralized/dionized water system? This closed loop system includes a demineralized water regenerator (resin media filter tank).
RE: Oil Removal from Demineralized Water System
Depending on the volume of your system you can go either with an oil water separator or a Racor type coalescing separator with a manual or automatic drain.
You lubrication supplier maybe able to lend or rent you a centrifuge type separator.
http://www.wlwalker.com/sites/WLW/sp_products.asp?subgroupid=220VLT
http://www.parker.com/portal/site/PARKER/menuitem.338f315e827b2c6315731910237ad1ca/?vgnextoid=94639bd01975e210VgnVCM10000048021dacRCRD&vgnextfmt=EN&productcategory=productline&vgnextdiv=687630&vgnextcatid=2622336&vgnextcat=MARINE+FUEL+FILTRATION&Wtky=
