Steam Dryer piping standard help
Hi
I am tasked with designing a pilot scale steam dryer using dilute flow transport at no more than 150 C. The system pressure is no more than 10 inches WC. The suspension vessel piping is 22 inch NP s10.
Steam is not introduced from a boiler but from the drying product.
Hope this is enough info.
I am looking for a standard for the large flanges but class 150 is way overkill for the pressures and temps.
Does anyone know of an applicable standard or am I stuck with overbuilding??
RE: Steam Dryer piping standard help
ASME B16.5
or make your own flanges out of 3/8th inch materials.. if small pipe diameters I would use slip on 150 class flanges and just weld on the outside.
