Vibe Input, Random or Sine?
The following vibration spec came across my desk almost on a cocktail napkin.
Vibration/ Shock Spec:
Frequency Range: 10Hz to 40Hz; amplitude = 0.1" p-p
40Hz to 2000Hz; acceleration = 4g RMS
Frequency Period: 30 minutes; 10Hz to 2000Hz and return
Test Time: 3 hours per axis
My job is to work with a test house to carryout this test. I'm assuming this is not a Random Vibe Test as the Amplitude is not specified in g^2/Hz, am I correct?
Thank you in advance for any advice.
-Tom
Failure is a prerequisite of successful design
RE: Vibe Input, Random or Sine?
TTFN
Chinese prisoner wins Nobel Peace Prize
sounds like poorly defined swept sine to me.
better go and ask them what they really want!
Cheers
Greg Locock
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
With the minimal experience/knowledge I have of vibration testing I would agree with GregLocock and figured that it was a Sine Sweep from this part of the spec:
"Frequency Period: 30 minutes; 10Hz to 2000Hz and return", Random vibe excites all frequencies at once, right?
"40Hz to 2000Hz; acceleration = 4g RMS"
Are the amplitudes of Sine Sweeps typically given in g RMS?
Cheers
Greg Locock
Simples
M.
Dr Michael F Platten
