Using SolidWorks Sheet Metal for plastic parts
I have recently started working at a plastics fabrication company as a trainee CAD / CAM designer. The line bending process is widely used with in the company for parts such as polycarbonate and acrylic machine guards etc. Up to now the CAD / CAM designer has been modeling the part in solidworks to comunicate the idea to the customer. If the customer gives the go ahead then the CAD / CAM designer will work out the "net" or flat pattern on paper before drawing it in a 2D design program so it can be cut out by CNC and then line bent.
Since I have started working at the company I have created a couple of parts using the sheet metal toolbar in SolidWorks, flattened the part and exported the face as a DXF for CNC, before line bending. However, these parts have not been very dimension critical.
I am wondering whether any one has any tips and tricks for using sheet metal for plastic parts? Obviously there is shrinkage involved in the line bending process and the bend allowance wont be the same in plastics compared to metals. Has anyone succesfully created dimensionally accurate line bent plastic parts from sheet metal in SolidWorks?
Thanks, I look forward to your replies.
RE: Using SolidWorks Sheet Metal for plastic parts
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
