NXOpen capture current directory
Hello -
I am trying to create a journal that when executed will create a separate .prt file in the same directory as the display part.  Is there an NXOpen command that allows me to capture the current directory of a displayed part?
I am using NX6.
Any help would be greatly appreciated. Thanks in advance.
RE: NXOpen capture current directory
workpart.FullPath 'Gets the fullpath of the file that is active (with the part name and the .prt)
workpart.leaf 'Gets only the part name
You could retrieve the string until the last "\".
spada
