Spectrum analysis combination of results with gravity
Greetings,
I have performed the spectrum analysis (in term of acceleration) of a solid object. I would like to combine the results of the spectrum analysis with the gravity effect on the structure. I thought this could be done using the ACEL command during the spectrum solution. But it seems that my results are equal in both cases. I guess that it doesn't work in the way I thought.
I didn't find nothing in the help. Do I have to combine the results of the spectrum analysis with a static analysis perhaps?
RE: Spectrum analysis combination of results with gravity
good luck
www.priamengineering.co.uk
