transportation and handling loads
Hi all,
Can some one tell me what kind of lateral load combination should I use for analyzing a structure subjected to transportation and handling loads. I saw in a sample calculation that they used the following combinations for lifting and handling loads respectively,
a. for lifting load
2g vertical
b. and for transportation loads
1. 1.5g lateral + 1g vertical,
2. 2.5g vertical load and
3. 1.0g lateral + 1g vertical.
this example does not cite from where these load combinations were obtained. Are these the right combinations or are there any other combinations ?
a. for lifting load
2g vertical
RE: transportation and handling loads
