MMC on a Surface
MMC on a Surface
i have a situation i am trying to resolve. my blue print has a callout of a diameter true position rel to -C- and -B-. both of them are surfaces and the geometrical feature control has a modifier for MMC on both datums. they are outside surfaces, so would i get more tolerance with the surfaces being smaller or larger ???
thanks
JJ
thanks
JJ
RE: MMC on a Surface
http://www
thanks
any help would be grateful
Application of (M) or (L) modifiers on datum features that are surfaces was introduced only in Y14.5-2009. Are you sure that location of datum feature symbols is indicating surface elements as datum features and not features of size for instance?
Frank
