composite impeller supplier
Hi
I'm looking for composite impeller suppliers (application: engine cooling/ seawater). Could you provide any suppliers name in UK/ worldwide. Any help is much appreciated
thanks in advance
Louis
thanks in advance
Louis
RE: composite impeller supplier
They specialise in sea water cooling pumps for engines.
Andy
We make water pumps for HD truck engines...Fortron material.
Hi hydromech,
At the moment any composite material will work as long as it works.
Do you design impeller with Fortron?
How good it is?
What range of duty point can it handle?
I am looking for a suitable replacement for metal impeller like iron, stainless steel
Can you direct me to some supplier?
Yes we design the impellers and then supply models to a prototype injection moulding company. Protomold.
The duty range is -40 to +120 degrees C.
We have single or double shrouded impellers and the plastic impellers serve as direct replacements for steel or cast iron impellers in water pumps for engines running with 50/50 water glycol.
Hydromech
This is not the way to go for a single replacement impeller.
The tooling for such impellers is approx £12,000 and piece price is about £15.
For a single replacement, you would be better to have it machined from solid material.
do you know the range of speed and pressure these impellers can handle?
a brief tech. spec might be in order instead of asking so many open-ended questions.
There are some bright and helpful people in this forum - but they aren't mind-readers
Plastic impellers are good for the typical engine speed ranges, gasoline or diesel.
The delta pressure across pumps are only up to about 3 BAR and the impellers manage that with no issues. Above 3 BAR, the engine components designers get a little nervous...radiator matrices tend to rupture.
