High Strength Concrete Patch
I need some type of high strength filler to patch "ruts" in concrete caused by rolling some heavy test beds on existing concrete. These ruts are starting to cause problems with our equipment and I would rather patch the ruts rather than replace everything.
thanks.
thanks.
RE: High Strength Concrete Patch
I would suggest steel plates. They can be in-set into the floor by routing or scabbling, and bonded with epoxy, which has a high strength.
Dik
