Inherit dimension options from another dimension - Catia V5R18
UG/NX has an option in Drafting that allows the user to copy(inherit) dimension  preferences(tolerance, dimension line, extension line, text, etc.) from another dimension that already has the prefered option.
Does Catia V5 have this option?
RE: Inherit dimension options from another dimension - Catia V5R18
yes. Select to dimension(s) to change, select the Painter icon (last icon in the Graphic Properties toolbar), select the dimension containing the properties to copy.
(similar to the windows Painter tool, but with reversed selections)
Thanks a lot!................I had known that, but since I haven't used in the last 12 months, I forgot!.....
