Refinery Base Octane Levels
I was curious what base octane that refineries in the U.S. run to. I had always assumed that the base octane was 87 and ethanol additions got you to mid grade gasoline. But now, with ethanol in most everything, do the refineries produce something like 85 octane as the base fuel and boost it to 87 with ethanol?
RE: Refinery Base Octane Levels
And now ,either congress has a bunch of chemical engineers or they are buying corn belt votes with ethanol and are making specific requirements on gasoline. And in round numbers, for every gallon of ethanol put into gasoline , a additional gallon of oil must be imported (to produce the corn/methanol); Not to mention the 30% loss of energy/gal of ethanol vs gasoline.
