V4 toV5 surface translation
How do I translate a V4 surface model to V5.  When I load in a V4 model no surfaces or faces come across.  I do wind up with "edge curves" in V5.  How can that be if I cannot find any surface?
RE: V4 toV5 surface translation
hi,
expand the MASTER tree (just like if it was a CATPart) in the window, you will find every entities build with v4.
You should find your surfaces, faces, points...
Be sure you do not have any FILTERS if you want to see all the MODEL.
have fun
eric
