Close and Trip Relay
As you know, in Protection system we usually use close and Trip relay between Main relay (as commander) and circuit breaker.
These relays must have to main features, Heavy duty and high speed.
The main use of these relays is that, when main relays (for example Distance relay) sends trip to CB, about 4ampere are used by inductor of CB.
hen the relay contact wants to break this current ,it must withstand Ldi\dt voltage . this voltage usually results to destroy main relay contact.
So, based on this philosophy which above mentioned, we use trip and close relay.
After improvement in CB mechanism, the CB contact position is used in the path of relay and CB coil. So the trip current is broken by this contact (for example after CB is tripped, the CB will be opened, so the CB contact will be opened and breaks the trip current)
But we still use trip relay and close relay between main relay and CB,,why?
For example we use 7PA27 Siemens relay as Trip relay and 7PA23 Siemens relay as Close relay.
I know just one reason.
RE: Close and Trip Relay
I see no purpose for an interposing relay between the protection relay and the breaker. As far back as our oldest breaker (60+ years) the breaker has included an 'a' contact in the trip circuit. Interposing relay is just something more to go wrong while providing no benefit. Lockout relays to keep a breaker open are somewhat different, but can also be a single point of failure.
Quote:
The main use of these relays is that, when main relays (for example Distance relay) sends trip to CB, about 4ampere are used by inductor of CB. hen the relay contact wants to break this current ,it must withstand Ldi\dt voltage . this voltage usually results to destroy main relay contact.
That's why you put a 52a contact in series with the trip coil.  It interrupts tripping current instead of the relay contact.
Oh, and by the way, there is also the equivalent of a 'b' contact in the close circuit. As far back as way before our oldest installation the relays have been able to handle the breakers. Trip and/or close aux relay that aren't lockout relays have probably never been justified. I'd hate to have to do the write up should something with a tripping relay fail and cause a misoperation.
Thanks All.
But one of its benefit is that in the CBF times (when CB was tripped but it was not opened.) the CB contact is still closed , so Ldi\dt will be opened by relay contact. if we not use trip relay , maybe, it leads to impair main relay contacts in that time.
on the other hand,these interposing relay are still produced by manufacture ( Siemens,ABB AREVa...) and also are in Protection Schematic drawings.
(note : the main use of these relay is not for making current, it is for breaking time )
(note 2 :  trip relay are not just between main relay and CB coil, it use between every thing should command open CB, for example discrepancy switch.  close relay as the same is between A\R relay and .... )
(note 3 :  trip relay and close relay price is about 400$ for each CB mechanism )
by considering all above items i think it must have a reason(s).
Not a good one that I can think of.  Sounds like a bad design.
@alivip.
1. As you have righly put in your notes and your initial explaination above, the main reason for the trip relay in the present day protection system has been reduced to that of a "multiplication" relay that multiplies the trip contact (from distance relays etc)and used further on for various reasons.
2. Further, the main relay contacts that are used for tripping a breaker are high speed trip contacts. The close / Trip coil of a breaker is rated at 200 W (approx) while that of the close / trip relay's wattage rating is at Max 10 W.
In order to maintain the High Speed feature, the available ways are either by reducing the mass or by reducing the energy requirement. Since mass of these coils have more or less remained constant to achieve the closing or opening operation, the only way to maintain the speed high is by reducing the Energy requirements. Thus by routing the trip / close command via a relay, you are reducing the energy requirement of the main relay(which are predominantly numerical these days.)
Now suppose you want to route the command directly, this would increase the energy requirement of these Main relays which inturn would increase the Rated Burden of the CTs and PTS/CVTs which consequently increase in the size of these instrument transformers and hence the overall cost of the system.
I suppose the cost of the above change will definitely be greater than 400$ and hence a Trip / close relay.
What????
Numeric relays run off power supplies and place almost no burden on the instrument transformers.  Your whole "2." doesn't make any sense.
thanks Inpran, but the same as davidbeach said :
the main relays (numeric and others) have separate power supply (they usually supplied with DC system(battery or charger), So the load of CB coil dose not influence on them at all.
the brief conclusion : the only reason we can find till now is :
To prevent damaging contact relay just(and just) in breaking the trip current when we experience CBF faulty.
Anybody knows more reason?
yes, this is a reason, to prevent damage of digital relay contacts. But not all comapnies are used some additional relays.
If an 86BF is used to retrip the failed breaker, it would protect the relay trip contact.
jghtist :
the CBF (when trip comes and cb will not be opened) results : the cb contact between main relay and coil dose not change position so the role for breaking trip current will be done by main relay contact. ( just in this state we need trip relay)
the CBF function (86BF) does not make sense in this topic.
No, it won't.  Just latch trip until the breaker opens.
when we have CBF, trip remains till fault clear(latch trip)
 ( fault will be clear by opening all CB connected to faulty CB ). so the CB will not be opened and the relay contact disconnect trip current.
My opinionion is also that separate trip relays (high-speed, high DC current breaking => high expensive) are not necessary now. But they are still required in tender documents and/or in utility requirements, so we continue to put them in new projects.
Some time ago I used another, much cheaper solution. Relay protection sends trip command to the CB directly. In the same time second contact of the relay protection, set also on "General trip", operates auxiliary relay of standard "contactor" type. Contact of this contactor duplicates trip command to CB trip coil. This way we still have high speed trip (without additional delay of external trip relay), but trip circuit is cut by powerful contact of the contactor, because relay protection's contact always drops-out first. Unfortunately I cannot implement this scheme in my current projects. I am sure it will not be approved - contactor type relay in 110 kV trip circuit doesn't look serious. It seems that my African client in that old project was more ready to accept some non-standard solution.
It may be like this in theory and practice, but in real life it is completely different.
The favourite sentence of my army sergeant
lz5pl :
your scheme is used in ABB protection scheme. AS you know ABB co. does not have trip relay and we use compounding tow set relay (one of them is high speed and for trip and other is heavy duty and used for breaking current). anyhow your scheme is cheaper.
Interesting discussion. We've just had a problem where a Micom relay was used to close and trip an old solenoid closing 11kV circuit breaker. The C/B has a closing contactor and the making duty (for the contactor) was within the Micom relay rating. However the Micom relay contacts burned out. One of the problems was that the closing pulse wasn't of long enough duration to make sure that the C/B "b" contact interrupted the solenoid magnetising current, rather than the relay in the Micom. We would normally fit an interposing relay in a sacrificial role as it's much less expensive to repair or change than an internal relay card.
Why not make the closing pulse longer?  In SEL relays, the CLOSE word stays asserted until either an unlatch condition (like TRIP) asserts, 52a closes, reclose initiates, or a close failure timer times out.  Can similar logic be implemented in the Micom?
Surge suppression for protective relay contacts dealing directly with trip and close coils is generally a good idea.
I try hard to avoid using interposing relays on trip circuits but it worthwhile to note that the most common protective relay failure for the new microprocessor relays is output contact failure.  Things happen.
These relays essentially already have an interposing relay built into the device in most cases, so adding another relay may decrease reliability instead of improving it.
David Castor
www.cvoes.com
David, you say about SEL surge suppersion solution?
Im use interposiong relay only by special request of customer or in some special cases.
Marmite, btw, in the laqst project with Micom relays, for close I was used interposiong relays ( it was local Areva recommendation)
SEL makes surge suppressors and they seem good, but there are other products that can be used.  I can't say we always use them, but if there is concern about the robustness of the output contacts, then the surge suppressor is way to reduce the wear and tear on the contact.
I have seen some PLC outputs welded when used to trip just a lockout relay.
Also, if using interposing relays on a trip circuit, make sure they are extremely high quality.  I have seen installation of some really wimpy interposing relays that were much less capable than the contacts they were supposedly protecting.
David Castor
www.cvoes.com
Once, I calculated price for such high trip relay ( must be a high speed relays, with 4-6ms make time)...for exmaple 6pcs. per one distance relay, with two trip coils and single phase trip, cheaper bay one spare card for numerical relay.
and number of CB faults today...near to zero.
last project, I used a very cheaper trip relay= 90Euro, please add wiring and place into cubicle.
So, Conclusion is :
1- the only use of Trip and close interposing relay is : To prevent damaging contact relay just(and just) in breaking the trip current when we experience CBF faulty.
2- number of CB faults today...near to zero.
3- Some consultant spec and clients still insist on using interposing relays
4- one of alternative relay : using power contactor parallel to main relay to coil (lz5pl scheme )
5- the price of using siemesn interposing relay for one CB (with 2 close coil )is about 600Euro.
i also don't understand about SEL Co. solution. is it possible to give me more detail information for this purpose.?
So, Conclusion is :
5- the price of using Siemens interposing relay for one CB (with 2 close coil )is about 600Euro.
Jg2828 : thank you.
if anybody works with SEL products , i like to have a compare with Siemens scheme about our topic subject.
i upload a file containing single line diagram of O.H.L
AS you can see, it contains :
3 trip relay for coil one
3 trip relay for coil two
1 close relay for CB close coil
1 lockout relay
3 trip coil supervision(TCS) for coil 1
3 trip coil supervision(TCS) for coil 2
the price of the following relays will be about 1300Euro based on Siemens products.
is it possible give me the same scheme based on SEL products?
Really you should just contact SEL if you are interested in their products.  They will be more than happy to look at your application.
David Castor
www.cvoes.com
Allivip,
in my thinking, a CBF faulty in 500kV-CB with trip coils of 500W to 800W, the main relay 7PA27 contact will be damaged and TCS 7PA30 will verify that the Trip Coil are OK.
 It will be necessary a visual inspection of the contact.
I guess this is not the purpose of the surge suppressor.
I dont know the exact use of surge suppressor , i will ask someone.
anyhow as you said
TCS(7Pa30) use is  : supervision of trip supply path of trip coil. it is used in closing CB interlock. if any fault exists in path of trip the TCS contact will be opened and the CB can not be closed (because in fault condition we can not open it).
Trip relay(PA27) : interpose between main relay and CB coil to break the trip current. it prevents damaging main relay contact.
External TCS today is not must.
Possible use build-in 74 function into Siemens relay ( or other ), but you need additional binary input for every trip coil.
alivip
excuse the mistake. In fact I never saw project with protection relay is used directly in the trip circuit. Always interposing relay is used. (94)
 It is very popular to use the relevant set of fast relay RXMS1 ABB in parallel with AREVA-CS1C contactor.
 I would like to know how to check if the trip relay(94) is suitable  to prevent damaging contact relay during CBF faulty.
Assume a trip circuit for a 500kV CB with a trip coil of 2.5 ohm in serie with resistor of 20 ohm .
Trip relay(7PA27)data:
 40A-0.5s-110VDC
1 contact non-inductive 125VDC- 1.2 A - 20 ms
1 contato inductive 125VDC 0.6 A - 20ms
Will be PA27 suitable?
Why would the relay output contact be damaged on breaker failure?  All you have to do is set the trip unlatch condition to be breaker open and then the relay output contact will not open until the breaker opens, even if that is hours later.
In transmission line protection with reclosing, a trip relay can not be latched relay type. After an operation of breaker failure scheme, with elimination of the fault, coil of relay will be desenergized and contact relay will opened by the spring return.
There's no reclosing on breaker failure, so that isn't a concern.  I'm not talking about a physical latch, just a logical latch until the breaker opens.  If the breaker fails, the trip will remain standing on the relay and will be interrupted by a relay tech opening the test switch, but long before then the trip coil will have interrupted the circuit by burning open, so still no issue.  There is no need for any type of interposing relay between the protective relay trip output and the breaker trip coil.  To do so is just to reduce reliability.
odlanor :
yes, based on Siemens answer you can series contacts of 7pa27 to reach this capability ( i think 3 set is required)
davidbeach :
it will be unlatched because when cbf is started other cb (connected to faulty cb ) will be tripped and they cleared the fault so trip will be unlatched.
other note : there is not only main relay tripping to cb, consider that re closing relay and discrepancy (or push button) also command to open cb .
If the unlatch condition is breaker open, opening other breakers won't unlatch the trip.
ULTR = NOT 52a
Simple enough.
Not in all cases used latched functionality, for example autoreclosere case .
Not in all cases to protective terminal is connected 52a signal.
Lot of versions.
And not always 52a contact is same position as main 52 contacts.
My conclusion is that the need for interposing relay is due to CBF faulty, at tripping circuit where 52a is used to break the trip current.
Based on the reasoning of David,I present a general solution. Tripping will be made by 2 contacts in parallel:
 1 - binary output for general trip of numerical protection relay.
 2 - blocking relay(86BF) of breaker failure protection applied into CB defective.
With this we'll have the compound scheme of fast and heavy duty tripping.
slavag,
Why necessity of interposing relays at closing circuit?
i don't to why we exactly use interposing relay in closing circuit.
may be when auto re close send close command and the cb close coil can not close the cb, the circuit will be opened by close relay instead of main relay contacts.
Why not use latched trip with reclosing?
Seems like an extra 52a contact and an extra relay input would usually be cheaper than a tripping relay.
By definition, 52a contact is in same position as main 52 contact.  I suppose that it is possible that the breaker will fail to trip, the 52a contact in series with the trip coil also fails to open, and the 52a contact energizing the relay 52A input does open.  Anything is possible, but if it is very improbable, you can live with a very rare relay contact failure.
jghrist
answer:
85% of the arc faults on overhead lines are extinguished automatically after being tripped by the protection.
In a succesfully reclosing, protection will reset and reclose command can be effective.
If use latched trip, close command will abort before a effective closing operation.
What is so difficult about latching the trip until the breaker opens?  Then it unlatches.  In plenty of time for the reclose.  This isn't rocket science, just basic protection engineering.
Good Morning.
I would like remaind, Im not use interposing relayssmile.
Maybe we have some misunderstanding.
But normal practic for protection and for CBFP (BFP, 50BF) not used 52a contact,only current ( ok not for all cases, low current situation is something other).
In system with autoreclosere alwayas used 52a contact, but only in terminal with this functionality, that menas in main 1 terminal, trip, not trrip contact is latched up to end of abnoraml situation.
Please take in account a problem case, not CBFP situation, breaker is openeed, but 52a contact in series with trip coil was not opened, only one contact.
alivip,
I think your explanation is not applicable to single shot reclosing.
slavag,
It is not so simple. I always use interposing relays. It is a cultural issue. To delete it I need to be persuasive.
Hi.
Yes, its something historical.
Someone need decide, with or without.
From technical point of view, iterposing relays are not needed, imho
Perhaps it is cultural, but I've seen nothing that suggests any benefit to interposing relays and lots of disadvantages. Those interposing relays seem to be a solution in search of a problem.  Our protection practices, without any such interposing relays, accomplish everything that the interposing relays supposedly make possible. If all the "benefits" of the interposing relay can be achieved without the interposing relay then good engineering practice is to eliminate the interposing relay and reduce the possible failure points.
i hope some one who has connecting with Siemens ask from them why they produce trip and close relay.
Siemens it something very big smile.
I have noe some projet with Siemens w/o any inerposing relays.
anyhow Siemens produces 7pa23 and 7pa27 relays for many years and surly they have philosophy for their uses.
btw.
Close relay is other issue, from time to time we use it for duplicate contacts, for Manual Close indication (SOTF, distance protection and for end-fault protection or BBP protection of coupler)
Anybody can help us about SEL set relays for this purpose Vs Siemens?
Based on my information :
Close relay  :  Siemens (7PA27)   SEL (?)
Trip relay   :  Siemens (7PA27)   SEL (?)
TCS  relay   :  Siemens (7PA30)   SEL (SEL 2652)
lockout relay:  Siemens (7PA23)   SEL (?)
I also found SEL-9502 Contact Arc Suppressor , is that use for the same purpose as trip or close relay?
Alireza
AFAIK, SEL does not make a utility-grade interposing relay or lockout relays.
For lockout relays, US suppliers would be Electroswitch, GE, and Shallco among others.
The SEL surge suppressors are not relays, they are connected in parallel with the relay output contact and reduce the surge voltage that the output contacts have to withstand.
David Castor
www.cvoes.com
SEL does not make trip, close, or lockout relays.  The SEL-2652 does exist, but we can do the same thing by connecting an input to the trip or close bus and don't bother with a separate device.  Lockout relays would typically come from somebody like Electroswitch.  The Contact Arc Suppressor (SEL-9501 or SEL-9502) will absorb the voltage, and therefore reduce/eliminate the arcing, that could be caused if the relay output contact tries to interrupt trip or close coil current.
They also have optional hybrid contacts on many relays.  In the hybrid output, there is a solid state relay that is used for making and breaking while a mechanical contact does the sustained current carrying.
thanks,
but i hope i could find the same suitable replace for Siemens interposing relays,do you have any suggestion from number one brands?
i don't know  electroswitch co. As i know the only number one brands for relay are :  ABB. Siemens, SEL AREVA GE
i think , it is right that SEL-2652 is not trip or close relay, but it is good replacement for trip relay. i mean we can use this relay instead of 7PA27 relay
GE makes lockout relays - GE HEA
And GE makes utility-grade aux relays:  See GE HAA, HFA, and HGA.
These have been in production for 50 years at least.
An interposing relay in a trip circuit is not a place to start comparison shopping.  Buy something with a proven history and don't get too concerned about saving money.
David Castor
www.cvoes.com
ABB for many years make Combiflex series relays.
RXMB, RXMS ( very fast tripping relays), RXMD (bistable relays, like to LOR, but electrical reset).
But need some expirience with wiring and ordereing of such relays.
In the same series TCS relays--SPER1B1, SPER1C4.
In the last project, I was used not bad interposing Spanish relay ARTECHE RF-4R, also nor so expansive.
Actually for simple trip relay is possible use a good range of power realys, like to Finger.
Trip coil supervision, possible use a nice Germany product
TSG910, TSG930
SPANISH ARTECHE RELAYs have good price , BUT IT IS NOT accepted by consultants,
GE and ABB are a good choice but their package for trip tcs lockout are more expensive than Siemens relays,
i hope i could find them in SEL products..but i cant find anything.
I am using ,just now, Spanish relay ARTECHE RF-202XR and RF-4XR - T<5,5ms.
is it SEL-9502 Contact Arc Suppressor good replacement for close and trip relay (7PA27) ?
They aren't even the same thing.
