Results from analysis
My particular problem involves contacts and I have decided to conduct a dynamic implicit analysis (i.e. considering the density of the material) and standard static analysis. Am I correct to assume that if, the stress results are the same for both analysis then I can ignore the dynamic/intertial effects?
