Line weight on FCF
Line weight on FCF
Attached is a composite feature control frame, may I ask how to change the line weight on the feature control frame and makes it match with the text.
Thanks for the help and your inputs
SeasonLee
SeasonLee
RE: Line weight on FCF
The method you stated is changing the font style to match with the line weight, what I want is:
1. How can I change a thin line to a heavy line on the feature control frame.
2. How to change the geometric tolerance symbol, diameter symbol and circled M symbol in order to match with the existing font style.
Thanks again for any inputs.
SeasonLee
Format >> Lineweight >> select a heavier line and set as default
Thanks any way
SeasonnLee
Changing the lineweights in the layers will not work.
You can not refedit or explode this tolerance command.
