Pin Gauge Use
Pin Gauge Use
Can someone point me to where a detailed example of how to use a pin gauge? I am setting up an SOP and want to reference something outside of our company to show standard practice/use.
RE: Pin Gauge Use
Note that this opnly applies to the standard gauge pins, properly called "Minus" pins. Reason for the Minus is that you cannot put a 0.150" pin into a 0.150" hole. Minus pin sets are made with each pin, IIRC, 0.0001" undersize. Allows just enough clearance for the gage pin to go into the hole.
RE: Pin Gauge Use
h
