spreadsheet to nx
spreadsheet to nx
Hi
I have created excel sheet for spur gear by considering all dimensions , and i want to create a design modelling in nx 7.5 by importing this sheet so , how can i do it.
RE: spreadsheet to nx
You can find a common gear design utility in the %UGII_BASE_DIR%\localization\prc folder.
You only have to set the UGII_COUNTRY=prc environment variable to use this utility.
