How do I move the nurbs mesh to fix this problem?
Howdy all,
I'm trying to create what I would think would be a fairly straght forward loft between two sections. The sections are parallel to each other, but one is slightly larger then the other to account for the taper on a flight control. There is a dip or fold in the top surface that you can see here:
http://f iles.engin eering.com /getfile.a spx?folder =42287d94- b31c-448a- 98bd-6eb7c 811bbfc&am p;file=Exa mple_1.JPG
I'm pretty sure this is caused by the nurbs mesh which you can see here:
http://f iles.engin eering.com /getfile.a spx?folder =cf0fddd5- 3f13-4a3b- a636-6aa81 a81e0c1&am p;file=Exa mple_2.JPG
I've tried a few methods of changing the end constraints in the loft, but without success. Is there a way I can get these nurbs lines that form the mesh to straighten out like I expect them to?
Thanks for everyones help.
-Kirby
http://f
http://f
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: How do I move the nurbs mesh to fix this problem?
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
-Kirby
Kirby Wilkerson
-Kirby
Kirby Wilkerson
