read an unknown number of lines into arrays
I need to read in an unknown number of array elements. i do not know how to handle the dimension of the arrays.
I start with declaring the size of each array as 101, but the file includes an unknown number of array components so I would nee to resize the array, which cannot be done in the middle of the code. the data file is attached (http://files.engineering.com/getfile.aspx)
Here is the code for now:
program main
parameter(imax=101)
dimension th(imax),et1(imax),et2(imax),eph1(imax),eph2(imax)
open(5,file="farfields.txt")
read(unit=5, fmt='(a1)') dummy ! read dummy text
read(5,*) npoints,freq,phi
m=1
! form here on i need to read 5 arrays and I do not know the size of the file.
100 read(5,*,end=101) th(m),et1(m),et2(m),eph1(m),eph2(m)
print*,m,th(m),et1(m),et2(m),eph1(m),eph2(m)
m=m+1
goto 100
101 continue
mmax=m-1
print*,'mmax= ',mmax
close(5)
stop
end program main
program main
parameter(imax=101)
m=1
m=m+1
goto 100
101 continue
mmax=m-1
close(5)
stop
end program main
RE: read an unknown number of lines into arrays
There is no file at the link posted.
TTFN
Chinese prisoner wins Nobel Peace Prize
....then, allocate your arrays; which they shouldn't be declared with fixed length in the first, you need to declare them without size "dimension(:)" and allocatable.
...then, rewind the file and start over; this time, read the individual values for each array entry.
Then again, it seems to me that the number of entries in the arrays ARE known, you are already reading such value into your variable npoints...so, a program to read that with dynamically allocated arrays would look somethin like this:
program main
character dummy*120
integer npoints
real freq,phi
real, dimension(:), allocatable :: th,et1,et2,eph1,eph2
open(15,file="farfields.txt")
read(15,'(a)') dummy
read(15,*) npoints,freq,phi
allocate(th(npoints))
allocate(et1(npoints))
allocate(et2(npoints))
allocate(eph1(npoints))
allocate(eph2(npoints))
do i=1,npoints
read(5,*) th(m),et1(m),et2(m),eph1(m),eph2(m)
end do
close(5)
! do whatever you need to do with array data
stop
end program main
There are 361 lines of data after the third line, therefore you only need to initially read in the first three lines to discover the size of array required.
www.Roshaz.com quality, cost effective FEA solutions
