Pressure Vessel from HDPE?
Sorry for not being an Engineer, however I figure this is the best place to get a good answer :)
Are there companies in the US that have the ability to fabricate a PV from HDPE?  Talking about 3 to 5 bar pressure, gas only (inert) AND have a removable or latched head for ease of getting product in and out of PV.
Thanks in advance!!  I'm trying to sort out if it is possible and where to begin a query of firms that have the capability.
RE: Pressure Vessel from HDPE?
I am not in the USA. Could you describe the item as a pipe and design it to the piping code?
Alternatively there are international standards for GRP vessels and they are used in the petrochem industry.
Why PE?
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
Doesn't sound like a good idea- compressible gas in a plastic PV using a material that constantly creeps and is very sensitive to temperature - but if it meets asme sect VIII crieria then theoretically one could do it.
PE lined steel vessels are used in the petrochem industry.
