ASTM F-2248 Interpretation
For determining anchor loads, is the 2xLR blast load applied only to the glazing area or is it also applied to the frame area?
The reason I'm asking is that if the frames are wide, that additional area will increase loads, whereas blast load to glazing only will result in lower anchor loads.
RE: ASTM F-2248 Interpretation
