Bolt thread loading
Bolt thread loading
I was looking at this chart and I dont understand why the numbers are different. Says the working load for a 1/4 unf bolt is 160 lbs (tensile) yet underneath on the lower chart is says 2700 for the same bolt.
http://do dgeram.org /tech/spec s/bolts/SA E_bolt_str ength.html
http://do
RE: Bolt thread loading
For the lower chart, they are using the tensile strength of the material (as opposed to a design strength). Obviously, it would be much higher.
Brian
www.espcomposites.com
This chart is worth what it cost you:)
Mike
First table:
- P/A (root area) = 6,000 gives you the first load = 160. This is just a "design stress" of 6ksi that they chose.
Second table:
- P/ A (root area) = Ftu gives you another load. At about Ftu = 75ksi, this gives about 2700 lb.
So it looks pretty straight forward to me.
Brian
To crunch some numbers from your chart:
Working Load Chart: 160 lb / 6000 psi = 0.02667 in^2 root area for 1/4 UNF. I get at least 0.0326 in^2 from said Handbook
Breaking Strength Chart: 2700 lb / 0.02667 in^2 = 101,000 psi. I doubt I would trust this for a GR 2 "iron" bolt.
2700 / 160 = about 17 (factor of safety, if you believe 2700).
All tensile, all assuming enough thread engagement to fully develop the strength of the bolt. Which is pretty much normal practice.
Nothing against Geno, but I'm sure there is much better info available on the 'net.
Mike
John, I think your problem is that you are trying to use the shear strength to calculate a tension failure mode, which does not make sense. To calculate the tension LOAD capacity, there are two failure modes. One for tension failure, using the root area, and relates to the loads you are asking about (160 vs 2700). The other failure mode, due to shear of the threads is a separate matter. The actual capability is the minimum of either.
Either way, it does roughly add up. Your question asked why are they so grossly different (160 vs 2700). That should be clear now. As stated previously it is simply the fact that one calc is basing it on a design stress and the other a material strength. Nothing more to it really.
Brian
h
Their(Fastenal) cross section area (Ats) differs from the Machinerys handbook (tensile strength area).
....""Thread Stength
Two fundamentals must be considered when designing a threaded connection
1.Ensure that the threaded fasteners were manufactured to a current ASTM, ANSI, DIN, ISO or other recognized standard.
2.Ensure that the design promotes bolts to break in tension prior to the female and/or male threads stripping. A broken bolt is an obvious failure. However, when the threads strip prior to the bolt breaking, the failure may go unnoticed until after the fastener is put in service.
Internal Thread Strength Formula
F = Su * Ats
Su = shear strength of the nut or tapped material
Ats = cross-sectional area through which the shear occurs
The strength of bolts loaded in tension can be easily determined by the ultimate tensile strength. To determine the amount of force required to break a bolt, multiply its ultimate tensile strength by its tensile stress area, As.
Determining the strength of the threads is more complicated. Since the male threads pull past the female threads, or vice-versa, the threads fail in shear and not in tension. Therefore, the stripping strength of an assembly depends on the shear strength of the nut and bolt materials.
Formula for Ats (when shear occurs at the roots of the thread)
Ats = π n Le Dsmin[1/(2n) + 0.57735 (Dsmin - Enmax)]
Dsmin = min major dia. of external threads Enmax = max pitch dia. of internal threads n = thread per inch Le = length of thread engagement
My college text book on machine design was Design of Machine Elements, by Virgil M. Faires.
Faires discusses the problem of a mechanic with a standard set of tools, tightening your bolt whatever way he darn well pleases. He comes up with the following equation...
Fe = Sy As3/2/6
For a 1/4-28UNF bolt, stress area As=.0364in2. My textbook shows a proof stress for a grade 2 bolt of 55000psi.
Fe = 55000lb/in2×(.0364in2)3/2 = 52lb
Note how the unit balance does not work. This is an arbitrary analysis of an uncontrolled assembly procedure. If you specify torque or some other assembly procedure, you can manage higher loads.
It would be nice to know Geno's Garage did their calculations.
This formula from Fastenal Corp is confusing and seems way off. The shear area (Ats)seems like it is 10x off
F = Su * Ats
Ats = pi n Le Dsmin[1/(2n) + 0.57735 (Dsmin – Enmax)]
of external threads
Enmax = max pitch
n = thread per
inch
Le = length of engagement
Of course the different areas will give different strengths.
Per the Tables 3 the fine threads have larger areas. We can easily see this by looking at any two bolts, the threads are not as "tall" on the fine thread.
The differing and less than obvious assumptions and level of quality from sources such as Fastenal, Genos', etc. is why Codes and standrds were developed.
Mike
http:/
ht
Yes finer threads are stronger
http:
desertfox
htt
That coarse threads are better from a stripping point of view than fine threads.
desertfox
