Inverter base solar generation
Is an inverter based solar generation a true grounded 4-wire wye system that allow zero sequence current flow?
RE: Inverter base solar generation
It depends.  The inverter probably isn't, but the isolation transformer included probably makes the package so.  If it matters it is best to get specific product information from the manufacturer.
Thanks davidbeach. It is just the inverter.
