ST extraction system
We have noticed that for some reason in order to achieve full power we need to close the 3rd extraction from the LP TV. How can this affect the TV?
RE: ST extraction system
Can you post a heat balance?  I don't understand the acronym "TV".  Since this is an international forum, acronums may not always mean the same thing to others.
If you are having to isolate a heater, it means that you are sending more steam down through the turbine which is helping you achieve full power.  It is however, most probably hurting your heat rate.
rmw
I mean ST (Steam Turbine)sorry.
