Repetitive constraints
Hi All,
I am working on an assembly which is migrated from IDEAS to NX 7.5 and has lost all the ocnstraints in it. There are many nuts, bolts and washers in it which require repetitive constraints commands. Is there any way to copy sequence of constraints and then apply it to required parts.
Thanks in advance!
RE: Repetitive constraints
You can use 'Remember Constraints'
