Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I train people in ACCESS. I make sure they know about these forums, give them some training on how to use the site, and have a shortcut to it on their PC's..."
Geography
no77 (Industrial)
15 Jun 11 20:22
I used arena simulation while in school.Fairly new at my new position and will like to tackle a process flow issue. this is a warehouse process where workers are inducting units and the empty cartons are then process onto a line, which is later fed to a different group of individuals who will then use these from the inductors to ship units to the real world. The current bottleneck we are assuming is the flow of the boxes from the inductors to the closers who uses the same boxes-they find themselves waiting on these boxes. Will like to simimulate the process. What are the variables that I will need to collect example the speed of the line that conveys the boxes and.......
tripleZ (Industrial)
26 Jun 11 8:22
The model setup itself is fairly easy, although it's been about 10 years since I last used Arena.  Your biggest challenge to start is tracking box arrival/departure rates for all of the points.  You need to determine the time distributions of these to see if they fit a standard distribution or if you have something else going on.  For instance, boxes arrive based on some sort of normal curve but conveyor errors cause blips in the system.  That's a start.  Obviously if you have a high number of SKUs this model could become complex very quickly.  If you're running a system with a lower number of SKUs it's less complex.
Arena will allow you to add conveyors, time distributions for conveyors as well as VA points, plus allows you to model in sub-routines to cover downtime occurrences.
The biggest thing I will tell you from past experience is that once you have a model developed and it has run into a steady-state output range, you need to validate it against your current system.  If you're dramatically off, you end up going back to your model to see where issues might be occurring.  I won't state that simulation won't help you, but you may find some other options exist for identifying and tracking bottlenecks without going to the efforts of developing an accurate simulation model.  It all depends on how complex or simple the system is.  My experience with distribution centers to date is that they usually feature a very high number of SKUs and model development is very time consuming.
no77 (Industrial)
29 Jun 11 2:04
thanks tripz for the info,very helpful. My focus is actually tracking the number of corrugates that is being used the an induction and closing station.cartons from induction stations are channeled thru a tunnel which is then used by the closed.Trying to find out if I can as simulate this process to see if there are enough cartons going to the closing stations.
Close Box
Join Eng-Tips® Today!
Join Us             Close
