changing drawing link to model
I have been asked to create a number of drawings all very similar to each other.
I have created my first drawing linked to the 3D model.
I would like to be able to create several variations of the model each varying slightly in size but...then be able to create copys of the original drawing updated to the new models. Is solidworks able to do this? I shouldnt have to redraw everytime.
RE: changing drawing link to model
If using multiple model files, do this:
1. Create model 1 and drawing 1.
2. From Drawing, SaveAs to drawing 2... before clicking save, click on references. A new window will pop up allowing you to assign model 2 to the model that drawing 2 is looking at. Click save.
3. drawing 2 will be active and will be looking at model 2. Drawing and model 1 will be unaffected. Go ahead and make your changes... rinse and repeat.
Another option is to use Pack&Go... which is functionally very similar... I just happen to prefer the method stated above... it has been around since the early days.
-Dustin
Professional Engineer
Pretty good with SolidWorks
I make a copy of the drawing in Windows Explorer and rename it. In Solidworks, go to file open, and select the renamed copy you want to link to a new part. Click the reference button at the bottom of the file open dialog. Double click on the reference that is shown to the old part, and point it to the new part.
-Dustin
You can use SW Explorer to make copies.
Or, open the model and its drawing.
Go to the model, save as to new name, then go to drawing and save as new name. Do this in this order as many times as you have variations of the model. But, they will be separate models with their own associated drawings.
Or, create configurations of the one model. "Save as" the drawings for each configuration, then change the model in each drawings to link to correct configurations.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
