Obtain contact between components in Solidworks
Hello all,
Is there anyway I can model two components in Solidworks, position them and determine the contact area between them? I that the contact area will depend on the load between the components, just wondered if anyone had any thoughts/experience with this?
Thanks.
Thanks.
RE: Obtain contact between components in Solidworks
The first thing that comes to mind is to save the assy as a part, then use the combine feature and substract leaving the surface? Then use measure command for surface area.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
