Is it possible to extract HEC RAS data in X,Y, Z coordinates format
Dear All,
HecRAS usually uses x y z coordinates data and changes into the elevation and river reach. But what I want to do is do the reverse. I want to use the information given in HECRAS to find out. X y z coordinates. I know HecRAS doesn't require the exact coordinate system but I have some data from another source to find the reference exact coordinates. I don't know whether it is possible to extract data in the format I described. Would you please give me some advise so that I can start ?
Thank you
Jdcivil
Thank you
Jdcivil
RE: Is it possible to extract HEC RAS data in X,Y, Z coordinates format
Thank you for your suggestion but I don't know how to export gis data from HECRAS model. Would you give me some ideas or examples so that I would be able to perform the export process ? Thank you so much.
