Steel 1144 FRP
Steel 1144 FRP
I have a specification for Steel 1144 FRP 280-330 BHN, for use in making a Pinion Blank. Can somebody enlighten me as to the use and properties of this steel.
Any help would be appreciated.
JSBCintl
JSBCintl
RE: Steel 1144 FRP
280 BHN is about 134,000 psi tensile strength.
This is a direct hardening steel as opposed to a carburizing grade. In other words, it has sufficient Carbon to respond to quench and temper without the need for carburizing.
The medium Carbon (.44%) allows for enough surface hardness for reasonable wear resistance at light duty and the Manganese provides for some depth of hardening to support the the sub-surface contact stresses of a gear tooth. The Sulpher creates Sulfide inclusions which act as stress concentrators or initiation points for fatigue failure. However, if the stress is below the endurance limit, the design is viable.
I do not know what the FRP stands for but someone will likely answer this.
RE: Steel 1144 FRP
Data here > http://www.niagaralasalle.com/downloads.html
Good luck.
