is there any utility which can convert NX6 part to NX4 part
Is there any utility to convert already existing NX6 part to NX4 part.. I can do the parasolid out and parasolid in to NX4 file, but I will loose the drawing.. I was to keep the drawing also..
NX6.0.5.3
RE: is there any utility which can convert NX6 part to NX4 part
You could try using IGES or STEP.  However, there is NO NX utility which will 'convert' a newer NX Part file into something which can be opened in an older version of NX and still retain such things as features, assemblies, drawings, etc.  Other than using a standards-based translator, as I suggested above, the officially supported built-in workflow only allows the unparameterized Solid/Sheet bodies to be 'down-versioned' via the Export -> Parasolid function.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
There is NO conversion utility that will keep a drawing associated to the model.
Use STEP or IGES for the model and DXF or IGES for the drawing.
Ben Loosli
