conflict with ANSYS workbench and APDL using bolt pretension
Good afternoon,
I've got a tightened nut problem that is giving me conflicting results in ANSYS. Both models have the same dimensions and material properties (not steel or aluminum, but linear). No other loads or BC's are applied, except friction contact between the nuts and members. The method I use for checking the preload is detailed below:
1.) Simple static calculations (EA/L) estimate that the total displacement (bolt stretch + member crush) required to develop the preload is 0.000331".
2.) I apply a bolt pretension load in ANSYS Workbench, equivalent to 8000 lbs. The solution comes back with 0.000501" required. 150% of my theoretical. However, I can believe this because the nuts and washers are also meshed and compressible pieces of the puzzle.
3.) I apply this same displacement, 0.000501, to an ANSYS APDL (aka "Classic") model. I do this by "modeling in" an initial penetration between the nut and the member, and letting the contact work out the rest.
To check whether or not the preload has been correctly applied, I look at the sum of the nodal forces (FSUM) on the surface of the nut. I put 8000 lbs in, so I expect to get 8000 lbs out, right? Wrong. The Workbench model says the FSUM is 10,000 lbs, and the APDL model says it is 4000 lbs.
What gives? Is it because the FSUM value is sensitive to mesh density or element type? Load distribution effects?
If this method isn't effective, what other suggestions does anyone have for determining the initial penetration to develop the required clamping force?
DBH
DBH
RE: conflict with ANSYS workbench and APDL using bolt pretension
why can't you directly preload to 8000lbf and check the displacemnt on either side of the 179 elements?
www.priamengineering.co.uk
