Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is easily the most helpful website I've ever used, and this is the best forum with the quickest response time bar none...."
Geography
sonckerr (Mechanical)
14 Jun 11 11:34
I work at a combined cycle plant and we also send steam to 2 hosts.  Where can I get information or how can I calculate the heat rate when taking this into consideration?
Romefu12 (Mechanical)
26 Aug 11 8:02
Are you wanting to calculate the heat rate of the gas turbine itself or the heat rate of the combined cycle plant as a total heat rate? The Gas Turbine heat rate is easy, however the total plant heat rate depends on many factors and will require some effort.
Gas Turbine Heat Rate as follows;
Heat Rate = Fuel Flow * Fuel Heating Value / Power Output to result in "X" BTU's/Kwh
For an overall plant or facility heat rate, you'll probably want to use the billing meters for both gas and electricity – and this should therefore be a net heat rate for the facility (after all auxiliary and house loads have been accounted for.as well as the steam flow to your 2 hosts.
The techniques re easily found on the internet
Romefu12
Close Box
Join Eng-Tips® Today!
Join Us             Close
