GE Spec to DeCode
GE Spec to DeCode
GE Spec to DeCode
I am trying to de-code GE Spec B8A3A (it is a shim stock of some kind .008 ) i have not been able to translate the type of material.  Can Someone Help?
RE: GE Spec to DeCode
a quick google of a few keywords brought this up: B8A3A sheet, hot roll, low carbon, ATSI 1010.
The .008 thickness does not jive well with a hot rolled material, or at least not what I'm used to seeing in shim stock.
I would get ahold of the appropriate division or department of GE and get it straight from the horses' mouth.
