Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...A lot of the information I've found at this site would've taken me forever if I'd have attempted to research it on my own. Thanks again."
Geography
AELLC (Structural)
13 Jun 11 11:18
I understand that the Size Factor modifies the Fb bending stress for 2,3,and 4 inch thick sawn dimension lumber (5" and thicker, the Size Factor = 1.00), and the size factor is based on edgewise use (load applied to narrow face).
Now, for flatwise use, the Fb is modified by the Flat-use factor.
This may sound contradictory, but do I modify Fb by BOTH the size Factor AND the Flat-use factor for flatwise use? Or, do I use ONLY the Flat-use factor?
The reason I ask is I have an old Code book which reads thusly:
"Flat-use Factor....When dimension lumber is used flatwise...the bending design value Fb, shall also be multiplied by the following flat-use factors:"
(Table follows, with factors ranging from 1.0 to 1.2)
MiketheEngineer (Structural)
13 Jun 11 11:52
I use both
frv (Structural)
13 Jun 11 11:59
Both. See Breyer et all.
AELLC (Structural)
13 Jun 11 12:22
Thanks Mike & frv
13 Jun 11 13:17
Just remember, you can only use the Flat factor when the lumber is actually used in the flat orientation.  Seems some people - fellow idiot engineers don't understand that!!!
AELLC (Structural)
13 Jun 11 13:41
"Just remember, you can only use the Flat factor when the lumber is actually used in the flat orientation.  Seems some people - fellow idiot engineers don't understand that!!! "
LOL, I remember a custom house where a very long span glulam beam  (it was deep mainly for deflection control) was hanger-supported to a short glulam header (the Bottom of Beam elevations were same).
The header glulam was designed much shallower than the supported beam, considering shear and bending were OK, but just the amount of nails thru the hanger appeared to put the header in danger from splitting the wood.
The jobsite workers had even started a betting pool where they guessed what date the header would collapse!
So in other words, the designer of that header should have realized it was stupid to try to save few dollars in a 4 foot long header, he should have spec'd a much deeper header.
Close Box
Join Eng-Tips® Today!
Join Us             Close
