Looking for 1962 or 1970 LH joist table
Does anyone have a pdf of the 1962 or 1970 LH load tables?  I am evaluating adding a light monorail to these existing joists.
Thank you.
Bill
RE: Looking for 1962 or 1970 LH joist table
Check with SJI - they have a book with all the old specs or for free on their website you can type in the specs and "probably" find your answer.
If you have the size - I have the book
Thanks Mike.
It's a 24LH06 and spanning 48'.
Bill
From 1962 chart, I show 307/150 with 48' being the longest or maybe the max.  150 being max live load w/ deflection at 1/360.
Good luck
WDM -
BTW - if you do a lot of remedial work - you can buy the book from SJI - I think $75.  It is worth it.
Thanks Mike.
Bill
