Custom symbols/tables problem
Hi all,
I'm creating some custom symbols but seem to be running into a problem. I can create the part, create the symbol, then pull it back for re-use. However, when I create a new part and go to find the symbol it isn't available.
I'm obviously missing something, any help appreciated.
RE: Custom symbols/tables problem
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I hope you are well?
NX7.5
Now you're already learned that storing a symbol in a part file only makes that symbol available while you're working in that part file and not with any other part file. So you need to save the symbols in an actual reuse library folder. To do that, go to...
Customer Defaults -> Gateway -> Reuse Library -> Symbol Library
...and in the box titled 'Symbol Libraris' enter the desired name for the library and the full path to the top level folder. If you're not using Teamcenter then enter the path to a native Windows folder in the upper box. If you're using Teamcenter enter the infodba path as defined in Teamcenter in the lower box. The format should look something like...
My Symbols|D:\User_files\symbols
...where the entry before the '|' is the desired name of the library as it will appear under the Reuse Library tab on the Resource Bar or in the Folder View section of the Custom Symbol dialog. Now you can have subfolders in this top level folder and they can go as deep as you need them to be.
Anyway, once you've set-up your folders when you create a Custom Symbol, rather then selecting the folder named 'Part part Symbols', select one of the other and save your symbol there. Note that since you will in actually be saving a specially formatted NX part file into this folder (that's what a Custome Symbol actually is, a special type of NX Part file) you will be asked to supply TWO names, one which will be the actual SYMBOL name and the other for what you wish to name the part file (they can be same name or different, that's up to you).
Now that you're saving the newly created symbols in an actual Reuse Library folder, you will be able to access them for use in any part file that you wish.
BTW, if you're running native Windows and you would like to access a set of system provided Symbols which are part of the NX install, include the following entry in the top entry box on the Customer Default page described above...
PMI Symbols|<where NX is installed>\UGII\symbol\PMI_Symbols
...making sure that you use the path name for the NX install location.
Anyway, I hope this helps solve you dilemma as to "Where dis my symbols go?"
John R. Baker, P.E.
Industry Sector
Cypress, CA
I have exactly the same problem as technicalconsultant got. Now, due to the excellent post of John i could partly solve the problem. But, is there any possibility to transfer those symbols in the part library to the open library created with the method above?
thanks for your replies
dominic
John R. Baker, P.E.
Industry Sector
Cypress, CA
http://www.plmworld.com/museum/
Thanks for your reply. Your assumption is right, except that it was myself that put those symbols into the part library. It is the first time i'm trying to work with the custom symbol library, and I made exactly the same error as technicalconsultant.
So if there is no easy way to transfer those symbols, i'll redraw these and save them this time in the created custom symbol library accessable for all parts.
John R. Baker, P.E.
Industry Sector
Cypress, CA
