bearing clearence
bearing clearence
When using lead to check clearences do you measure the thickness of the compressed lead, or the width of the compressed lead.
RE: bearing clearence
The product plastigage is "read" by measuring the width, but it is based on a "calibrated" diameter of the original plastic string, and a particular material, and the volume remaining constant pre- and post- squishing. Plastigage is available in a few sizes to cover a ranges of clearance from 0.001 inch to at least 0.009 inch.
http://www
The outfit in England claims to be the originator, and has product to measure up to 70 thou.
http://www.plastigaugeusa.com/pricelist.html
Plastigage is good stuff but it doesn't work in all applications.
David
