slab with double layer of reinforcement
Reinforcement to control cracking in a spillway slab is of the order of 60cm2/m.
If the reinforcement is placed in two layers the reinforcement cover should be considered as the average cover (layer1 + layer2)/2 or that of the first (top) layer.
RE: slab with double layer of reinforcement
I was rather confused because if someone placed lets say 3 layers,I quess the sections effective depth for structural analysis would be the average depth but for cracking I quess it makes sense to consider the outmost layer.
I suggest you do a search on concrete design as it appears you have a bit to learn. This forum is not really the place to learn the fundamentals.
1. normally you would not use more than 2 layers of reinforcement (one in each direction). this would be repeated at each face.
2. you would then use the actual depth of the reinforcement in the particular direction for strength calculations.
3. cover is as it sound, the minimum amount of concrete covering the steel i.e. the smallest distance from steel to edge of concrete.
