ferrite number
ferrite number
I have a weld procedure for austenitic steel with solution annealing. now there is a requirement of ferrite Number of weld metal. Can I weld a test sample only to conduct Ferrite Number test on weld metal using the same consumable brand as that was used for PQR and add as a addenda to PQR?
RE: ferrite number
