Section Line in NX6
Section Line in NX6
Section Line in NX6
OK, so I know that you can no longer toggle off section line display in NX6. They want us to use Hide instead. My question is, when you open a file that was created in a previous version and the section line display was toggled off, how do you bring it back?
RE: Section Line in NX6
Nevermind, figured it out. By right-clicking on the section view and going to style, you toggle the display section line box. If it is already checked, which it was in my case, uncheck, apply, re-check and OK and your line will be there.
You can still hide the crosshatching as well as the section (cutting plane) line in NX6, just as in previous versions.
You really don't want to use "hide" for something like this anyways - it will just cause problems down the road - hide should only be used as a temporary hiding.
