How can the naptha hydrotreating reactor pressure drop normalized?
I have naphtha hydrotreating reactor.I need to monitor the reactor pressure drop trend.I need to normalize as it is affected by the feed rate and the recycle gas.Actually, when I normalize it to the feed rate only, the recycle gas effect is neglected.when I normalize it to the recycle gas, the feed rate effect is neglected.
It will be appreciated, if any body can help me to normalize it regarding both of the feed rate and the recycle gas to obtain a reliable trend.
Thanks.
RE: How can the naptha hydrotreating reactor pressure drop normalized?
I think naphtha hydrotreaters run in 100% gas phase. So just convert the total feed to gas, and normalize on that basis.
HAZOP at www.curryhydrocarbons.ca
Im not 100% sure that i got the question but one tip: For a mass ballance try drawing a simplified PFD and write all your know and unknown next to the line representing streams. This way you can visualise what parameters are known and unknown. Draw a box reprsenting the mass ballance and you will then know where you independant variable is (e.g. recycle rate).
Best regrads
Morten
thanks every one
May we know why do you want to normalize the pressure drop. How will you interpret this new normalized pressure drop?
"We don't believe things because they are true, things are true because we believe them."
