New Wood Allowable Shears
It appears that the 2005 NDS allows shear values in Glulams up to 50% more than previous.
My question is this: Is there any written guidance relating as to whether this is only applicable to new glulam beams, or is applicable to all glulams, say those made in the 60's, which would greatly affect remodels...
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
RE: New Wood Allowable Shears
My guess would be that you can't use the new shear allowables on old lumber or gluelam beams. I think this is all tangled up in new lumber grading rules and new allowable stresses which came with that. I think this all started back in about 95 - 99, with a major industry wide lumber testing vs. grading vs. actual failure stresses, 70 new adjustment factors, etc. The testing program actually had a name and influenced the stress values in the NDS supplement from about 2001 and on. I think the program was called the In-Grade testing program or some such. Read the introduction to the supplement and some of the commentaries on the NDS changes from that era, they may give you some clues.
I've had some of the same questions as I compare the older NDS versions which I was accustom to designing with and the newer versions of the NDS, about 2001 and forward. I was kind of out of the building design business, on a regular basis, for a number of years during that same period of time, so I wasn't paying close attention to all the changes and where they came from and their justifications.
My dates were wrong. The Forest Products Lab in Madison, WI started the In-Grade Testing Program in about 1978. The objective of the program was to come up with more reliable design values for existing grades of commercially available lumber, and to adjust grading rules to meet currently available lumber. They were testing full size dimensional lumber members which had already been graded, not just small clear samples. And, in the early 90's the new allowable properties started showing up in the supplement. And, of course, they added reams of statistical complexity to the whole process, so then they needed more size factors, and other adjustment factors, etc. etc. Look for a good write-up in Wood Engineering text on wood properties and grading, that should give you some direction and understanding. You might also look at the history of several of the ASTM standards on lumber grading and allowable lumber properties.
It makes me wonder how some of my older building are still standing, given how much I didn't know about the need for a 1.03 size adjustment factor and what I still don't know or understand about how much better the newer versions of the codes are for us all. If only we would get paid for all the time we waste on this crap. But then, I've never seen a building failure attributed to someone forgetting to apply a .96 or 1.09 adjustment factor; and have seen plenty of problems caused by stupid detailing or just not paying attention to how a structure really act and reacts to the way it was framed or detailed.
Mike McCann
MMC Engineering
Motto: KISS
http://
I'm not sure that it helps to explain things all that much though. According to the article it should be more like a 10% change in allowable shear for Glu-Lams.
That's one h*(( of a lot more than 10%!
Mike McCann
MMC Engineering
Motto: KISS
Can't seem to find the Design reference for the old, as the 2001 and 2005 NDS go with the 175 psi base value for my standby, Southern Yellow Pine.
This is of course for dimensional lumber, but I wonder if there was a similar swap in the GluLams?
What design spec are you comparing the durrent info to?
Daniel
3V/2bd is the horizontal shearing stress at d/2. Why would this change?
Do you always misspell buffoons, or did you just do that for the sheer fun of it?
